Hi,.can someone help me set up timescale to be working as exit node? When want switch on the toggle the IP list is all time empty. In tile scale admin console have two IP LAN I WAN approved. Don't know how to fix it…
Did you click the refresh button beside it to update the list?
For more specific steps, please refer to: Tailscale - GL.iNet Router Docs 4
Note that you need to approve the router's subnet in the Tailscale admin console so that client devices can route properly.
I have approved all I needed in timescale admin console, in router admin console clicked refresh but still list is empty.
Ok i have exit node fixed by changing a few settings in firewall traffic rules.
Now my devices when using tailescale connection are using router VPN IP but ISP DNS resolver, how fix it to use VPN DNS ?
On WiFi all devices normally use VPN IP and DNS.
Thanks
Do you currently use both Tailscale and a VPN client on the AX1800?
This scenario is not currently supported.
But if you just want other Tailscale Nodes to use AX1800 as their DNS server, you may try configuring:
Go to Luci - Network - DHCP and DNS - Filter - uncheck the "Local service only"
On GL UI - Network - DNS - Enable the "Override DNS Settings of All Clients"
On Tailscale Admin Console - DNS - Set the Tailscale IP of AX1800 as DNS and enable the "Override the DNS servers"
