I've been working with this for a while and researching possible solutions. So far no luck.
I am using an Apple TV and a raspberry pi 5 as Tailscale exit nodes. I'm testing my configuration on various devices including the AX3000. The AX3000 will travel with me and route all traffic through the exit node.
I have tested my exit nodes with a Mac, iPhone and iPad and they all work flawlessly with either exit node selected.
When I set the AX3000 to use Tailscale without an exit node all of the connected devices work fine. None of them are running Tailscale when I test the router.
When I set a custom exit node on the router all connected devices can't access the internet. This is the same result for the Apple TV and the Raspberry Pi.
I see posts about setting up subnets and I do get an error one the router telling me to do so. But since all other devices work just fine using these exit nodes I wonder if this is necessary.
I did set up subnets on both exit nodes with the same result.
Any suggestions would be appreciated.
Thanks.
