Same, it works but is excruciatingly slow.
Maybe mine is going through relays too? How can you tell? That would explain slow speeds.
You can do a traceroute / tracert from one device to the other and check the hops
Looks like mine is direct:
traceroute to 192.168.7.1 (192.168.7.1), 64 hops max, 52 byte packets
1 192.168.8.1 (192.168.8.1) 8.138 ms 2.926 ms 2.631 ms
2 192.168.7.1 (192.168.7.1) 110.967 ms 116.206 ms 114.027 ms
Not sure what has changed but now I am getting about 2/3 of my exit nodes bandwidth. I would expect close to 100% but I will take 2/3 if it stays at that. Yesterday I was only about ti get 1/7th.
I found a solution on the Reddit forums that works for me.
First setup your tailscale remote subnet router on the Mt3000 as usual. Then…
On the MT3000 Admin Panel
Under menu item System->Advanced
Go into the LUCI admin panel then select Network → Firewall.
By default, below you will see 3 zones:
- lan > wan
- wan > REJECT
- guest > wan
Click on “EDIT” on the second one ( wan > REJECT)
Then click on the second top tab “Advanced Settings” and in the covered devices dropdown select tailscale0. Save, Save and apply.
Now you should be able to route your Mt3000 Wan traffic to the designated Tailscale exit node, and the devices on the MT3000 Lan will also be accessible to devices running on the Tailscale net
One slight bug. On the wan side you will not be able to reach the admin console of the MT3000 via tailscale even though it is included in the subnet routing address you setup And you will not be able to access the admin console of the MT3000 on the lan side unless you turn off Tailscale on your local lan device, which is fine since all traffic on the lan side is now going over the tailscale net to the exit node anyway.
Hi eveyone!
This mod worked for me, but I had to downgrade my Beryl AX to firmware version 4.45
The gl_tailscale file of current firmware versions is significantly different.
With current versions, like,
openwrt-mt3000-4.6.0-0524-1716546849.tar
openwrt-mt3000-4.6.0-op24-0607-1717745322.bin
I tried to modify the gl_tailscale file like this:
if [ -n "$routes" ]; then
param="--advertise-routes=$routes"
else
param=""
fi
if [ -n "$exit_node_ip" ];then
add_exit_node_rule
param="$param --exit-node-allow-lan-access --exit-node=$exit_node_ip"
fi
[ -n "$lan_ip" ] && add_policy_route $lan_ip
[ -n "$wan_ip" ] && add_policy_route $wan_ip
[ -n "$secondwan_ip" ] && add_policy_route $secondwan_ip
[ -n "$wwan_ip" ] && add_policy_route $wwan_ip
[ -n "$tethering_ip" ] && add_policy_route $tethering_ip
add_guest_policy_route
while [ -n "$(ip rule show priority 1)" ]
do
ip rule del priority 1
done
ip rule add from all to 192.168.8.0/24 lookup 55 priority 1 # 192.168.8.0/24 is your xe3000 lan ip
timeout 10 /usr/sbin/tailscale up --advertise-exit-node --reset --accept-routes $param --timeout 3s --accept-dns=false > /dev/null
else
do
done
/etc/init.d/tailscale stop
fi
modify_dns_resolv $enabled
fi
No dice ...
Perhaps dengxinfa can help those of us not Linux versed (and me) posting a current version of his mod?
Thank you.
