I am having an issue getting internet access from my AR-750. The AR-750 is getting internet from a tethered smartphone using EasyTether. Wirelessly connected devices are able to access internet from the 750 just fine, but a laptop connected to either of the two LAN ethernet ports cannot access the internet.
Is there some setting or configuration in the router I need modify to enable internet through the wired connections?
There are three Ethernet ports on the back of the router - one WAN and two LAN, right?
My laptop attached to the wired LAN does get an IP from the router (and able to access the Admin panel, etc.). I’m just not able to get internet from it.
