Tethering prioritized over ethernet
GL-MT2500 Brume 2
Firmware release 8 version 4.5.0
Primary modem connected via ethernet (~150mbps)
Backup 4G modem connected to USB “tethering” (~50mbps)
Intended to switch over for fallback only
Multi-WAN
mode- fallover
Interface priority
  1. ethernet
  2. Tethering
When tethering is enabled, internet is routed over the USB/tether, instead of ethernet as expected.
Have tried adjusting “metric” in /etc/config/network which does not solve.
config interface 'wan'
        option device 'eth0'
        option proto 'dhcp'
        option force_link '0'
        option ipv6 '0'
        option metric '10'
config interface 'tethering'
        option proto 'dhcp'
        option ifname 'eth2'
        option metric '30'
solved
  • both tehered modem and primary ethernet router had gateways 192.168.0.1 which was confusing things.
  • Changed one to start at 192.168.1.1 and now all good.
