Three Suggestions/Requests - One Product One Forum One Documentation
Have three requests for changes I would like to see..
First, a way to disable the checks for updates (and any other 'telemetry'). Suggestions on how to implement.. If one disables the "cloud" function, also disable the checks for updates. Otherwise add an option to the update sections, but even the terminal would be acceptable. Some admins do watch what the hosts do and phoning home (for any reason) that can't be turned off is a red flag.
Second, have a location to check for the latest releases, both stable and beta. Pinned post here perhaps.
GL.iNet download center is slow to be updated and doesn't show the betas (removing 'stable' from the URL breaks it), Releases · gl-inet/glkvm · GitHub is behind.
Third, the user guide, GL-RM1 (Comet) - GL.iNet KVM Docs Please the inventory for what is (should be) in the box, and this applies to all of the products.. As an example, I didn't know it came with the power adapter, USB cables, HDMI cable, and network cable. I ordered these separately because nothing said they were included. This page Flint 3 (GL-BE9300)Tri-band Wi-Fi 7 Home Router — GL.iNet has an "In the Box" picture https://store.gl-inet.com/cdn/shop/files/17---US---Inside-the-Box---BE9300_1600x1600.jpg as an example but the documentation doesn't, the Comet doesn't have that at all.
Thanks for your kind suggestion. We will take into consideration about all the information.
