[Tip] to Increase Quality
Hey!
Here’s a quick tip to increase image quality. If you’re using MS Edge (not sure about the other browsers), you can click on the enhance button (pic attached) and it will increase the quality significantly.
The effect is obvious, thank you for sharing
