Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ar71xx/generic/packages/base/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_base.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ar71xx/generic/packages/base/Packages.sig.
Signature check failed.
Remove wrong Signature file.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ar71xx/generic/packages/packages/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_packages.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ar71xx/generic/packages/packages/Packages.sig.
etc.
Even though a few do pass the package list is not being updated
I only wanted to install nano.. at this point
I just found that there is a newer TOR firmware (1.3) Please update GL.iNet download center. That still points to 1.2 Or point it to the directory GL.iNet download center then you don’t need to update the download page .
The problem with 1.3 is a bit different now opkg update gives me:
Collected errors:
opkg_conf_load: Could not lock /var/lock/opkg.lock: Resource temporarily unavailable.
