ar300m
use most recent testing firmwares (3.105 GL.iNet download center)
I have option to “enable” tor and if I do this I can not log in (obvious) and also there is not more internet.
I have same problems if I use the button for Tor controls.
In the Tor UI, what is the message displayed?
It will display in which percentage the Tor is on. Does it stuck at 5%?
It does not display percentage. I click Apply and after, I see green message “Success!” and no more. I refresh page but get blank. I have no connectivity to internet and also not tor after this.
You have no connectivity to internet before using Tor?
Before I click “Apply” I have internet. After, not.
@alzhao You did receive my reply? I have internet. Then I click “Apply” to Tor. Then I do not have any internet/Tor.
Yes. I need to set up my AR300M and try.
@alzhao OK thank you. I try a few ideas but nothing is work yet. But also I can not access GL UI because of other issue. Password Stop Working After Upgrade GL UI - #6 by alzhao
@alzhao also v 3.105 has v 18.04 OpenWRT. This is correct?
18.06 no major update in openwrt version if not necessary.
Okay. I thought it should be one possible reason Tor not working (old Tor) but maybe is something else. Is really a problem I wish to solve.
@alzhao
Is one week now. Please, there is something I can do to fix this problem?
I will report back today.
I do flashed 3.105 and Tor is working OK.
I am using cable for Internet.
@alzhao
Very good for you but this is not true for me. So again I ask, what you think I should test to give you informations to fix? (I am also using cable for internet and I talk before about nand/nor.)
Several things to try:
  1. You try a different ISP
  2. You try an old firmware
  3. Let me check remotely and find a way for further analysis.
Pls also tell me your location.
@alzhao
I have other Tor connection with this ISP. Can not be ISP. Problem is GL UI does freeze, can not access if do Tor.
What you recommend, what is having Tor? https://dl.gl-inet.com/firmware/ar300m/nand/testing/
What is this mean?
Why?
Exact filename please?
3.105-1014
Need to check remotely using anydesk or teamviewer to understand the problem.
