Traceroute showing 5 internal hops before ISP network
This is a traceroute using my GL.iNet GL-X750 with latest firmware.
Why are there 5 internal hops using the private address space before it hits my ISP network?
There is no VPN or Proxy setup.
Tracing route to portal.unidenvoice.com [103.135.87.3]
over a maximum of 30 hops:
1 3 ms 3 ms 3 ms console.gl-inet.com [192.168.8.1]
2 541 ms 40 ms 267 ms 10.4.95.69
3 26 ms 28 ms 35 ms 10.4.95.83
4 * * * Request timed out.
5 27 ms 33 ms 37 ms 10.5.99.1
6 34 ms 25 ms 29 ms 10.5.99.2
7 34 ms 25 ms 29 ms 10.5.99.9
8 29 ms 29 ms 28 ms bundle-ether26.hay-core30.sydney.telstra.net [203.50.61.112]
9 27 ms 27 ms 27 ms bundle-ether1.ken-edge901.sydney.telstra.net [203.50.11.95]
10 29 ms 29 ms 27 ms gne3749650.lnk.telstra.net [139.130.235.134]
11 25 ms 29 ms 30 ms 45.112.245.81
12 28 ms 27 ms 29 ms 45.112.245.126
13 25 ms 28 ms 27 ms portal.vocphone.com [103.135.87.3]
Trace complete.
Looks like the CGNAT routes
Thanks but the same traceroute to the same ISP using a different router/connection (Telstra FTTN) does not have these. Are these used for 4G connections to Telstra’s data network?
Does your FTTN/ISP modem own a public IP? If so, it definitely has fewer hops.
You can learn about CGNAT
