Comet working good.
Have file on remote GLKVM...How do I send/copy to host pc?
Instructions: GLKVM> File, xfer, view, move, delete.
Don't quite understand instructions to move files.
Comet transfers files by simulating a USB flash drive. If you need to copy files to a remote computer, you need to mount the USB flash drive first. It will create a disk on your computer and you can use this disk to transfer files.
Given the options you provided: "File, xfer, view, move, delete," it's highly probable that "xfer" is the function you want to use for transferring files to your host PC. "Move" in this context usually refers to moving files within the GLKVM environment (e.g., from one directory to another on the GLKVM itself), not transferring them externally. Official Site
Thanks, I'll give that a try.
