Looking into a travel router that supports 5g and 2.4 with an included battery.
Basically I want a union of GL-AR750 and the Gl-MIFI, a plus would be USB-Type C for charging as all my new devices (phone, headphones, cellphone) use it and it means only one cable /charger, plus it supports higher voltages so it may be possible to adapt one of the 12v models. Maybe a faster processor 2cores for better openvpn support? I dont mind if it is a little bigger to accommodate a battery / antennas as long as it still portable (fit in my pocket)
Are there any plans for such a product?
How do you want to carry a 12V battery?
We do want to make such a product, but battery is not an option any more.
