I have a lot of trouble to connect to a 5G wifi as a client.
What worked so far:
- 2.4G client -> 2.4G AP
- 2.4G client -> 5G AP
Edit: I solved it, using the advanced configuration. It was not possible from the basic UI.
What worked so far:
which model are you using? AR750? The basic UI should work.
