Hello. I’m trying to setup OpenVPN using TunnelBear, following this: TunnelBear Befriends Penguins with Limited Linux Support
I was able to download all config files and imported to OPEL settings. After added my TunnelBear credencials, start the VPN and I get this error:
Sun Aug 6 17:12:33 2023 daemon.notice netifd: Interface ‘ovpnclient’ is setting up now Sun Aug 6 17:12:34 2023 daemon.warn ovpnclient[3231]: WARNING: --keysize is DEPRECATED and will be removed in OpenVPN 2.6 Sun Aug 6 17:12:34 2023 daemon.err ovpnclient[3231]: Options error: If you use one of --cert or --key, you must use them both Sun Aug 6 17:12:34 2023 daemon.warn ovpnclient[3231]: Use --help for more information. Sun Aug 6 17:12:34 2023 daemon.notice netifd: ovpnclient (3236): cat: can’t open ‘/tmp/run/ovpn_resolved_ip’: No such file or directory Sun Aug 6 17:12:34 2023 user.notice relay: Reloading relay due to ifup-failed of ovpnclient () Sun Aug 6 17:12:39 2023 daemon.notice netifd: Interface ‘ovpnclient’ is now down
I’m using the latest beta release 2 firmware v4.3.6.
How can I fix this? Thanks.
