Unable to access Plugins from GL.iNet Panel
I can’t access plugins through the GL.iNet Panel on the latest stable version, V4.4.6 for Slate AXT1800.
It works fine through LuCi & I can run “opkg update” without any problems through SSH. Same for installing packages.
It just doesn’t work in the GL.iNet Panel. Throws the “ -2,Network unreachable” error.
Please help to execute cat /etc/config/glconfig and check what track_ip are configured.Can you ping any track_ip successfully?
They can all be pinged (except IPV6. I have that disabled)
Do you have any firewall rule configured to restrict access to port 53? This error message is displayed when all the track_ip fail to connect using protocol tcp and port 53.
Maybe the DNS override?
Haven’t made any “custom” changes. Just what the GL.iNet panel allows🤷‍♂️
You can check it using nc "8.8.8.8" 53,and it will return in seconds if connection is successful. You can also capture the packet using tcpdump -i etho -vvvvv to check how long it actually takes to connect.The timeout set for detecting connections is 1 second. If connection is fails ,the nc command will get stuck.
Running
nc “8.8.8.8” 53
Worked fine, didn’t get stuck.
Running
tcpdump -i eth0 -vvvvv
Returns a lot of info xD
Update:
It’s working as usual now. No problems accessing plugins from the GL.iNet panel. I didn’t make any changes though, so I am unsure what “fixed” it🤷‍♂️
