Unable to do factory reset on GL-MT3000. Pressing the button does nothing
Two of the routers I purchased do not reset to factory setting. I keep holding down the button, but it does not start blinking as others have. Any ideas?
Reset the firmware to defaults using the option in the web interface?
If it does not reset, you should try to reset using Uboot:
