I can’t log in to brand new MT-6000 using the wi-fi key on the bottom of the router to set up admin. I get the message that the password is incorrect. Any assistance is appreciated.
Try a factory reset (using the reset button) - Repair or Reset - GL.iNet Router Docs 4
Thanks for your suggestion, but I’ve already tried that along with rebooting both the cable modem and router by disconnecting from power and plugging back in and no change. I’m open to other suggestions and ideas.
That's weird, are you sure you tried it completely?
Normally, the device won't ask for a password on first setup.
Can you explain what you do for getting this message?
Can you post a screenshot?
Oh, and Merry Christmas!
