I did everything in the tutorial to get easy tether to work, however two things didn’t match up.
When using putty to type : easytether-usb, the console comes back and says device not found check the easy tether app…or something like that.
Everything else worked with no problems
The other thing is that the device is reading the connection as a modem instead of a tether.
Any help is appreciated.
Thanks
