I have a windows 11 machine that I have connected to 3 RM10 comet pro devices in order to try to use the machine as a 3 monitor device. My plan was to open each "screen" or HDMI output into a separate browser window and switch between browsers to get more work done across the multi monitor setup. For some reason I cannot get this to work because the mouse seems to only function on one display like it is bound to that one device only. I have tried plugging in all 3 kvm to use as the mouse/keyboard, and customer support suggested I only plug in 1 of the kvm into the machine to use as the mouse (which doesn't seem to work once I click off the active window browser). I have tried changing from absolute to relative for the mouse control when all 3 are connected and that doesn't seem fix the problem either. The setup would be perfect if I could pull up the browser of screen 2 and click an icon and have it just track the exact location, then open browser for screen 1 and click a separate icon ect. I assume that is how absolute is supposed to work, but it just isn't working properly. Anyone have any suggestions? Thanks
Hi, we recommend using one KVM device per controlled device. If you use three KVM devices on a single Windows laptop to control different monitors, you may not achieve the desired results.
Everything works so well except the mouse implementation across multiple monitors. I would love it if there was a way to get it to work. For example sending the exact mouse position corresponding to the pixel on each different virtual display.
This could be a limitation in Windows.
One important thing to know what increase the likehood that this happens is if you mirror monitor.
Or duplicate them and then the monitors have each a different resolution.
