How many Filters do you have enabled?
Adguard is a memory hog. I disabled it on the router because of it gradually slowing to the point where I can’t login to the router and it must be reset. I just stick with the app on devices that can use it without choking to death on memory. If you must use it on the router then I advise using just the basic filters until it is optimised properly. Not sure if it’s possible but if you can disable the filter log, like on a pc or smartphone version, that might help a little.
It’s been stable lately only using 2 filters.
