I have a mt300n-v2 and so does someone else in my dorm, if both are plugged in the connectivity starts to be intermittent.
I changed SSID in case it caused any issue, would it be MAC address or the network confusing the devices? Any tips?
By “intermittent”, do you mean the wifi is disconnecting, or losing internet while wifi still connected?
You can try changing the wifi channel, so they are not broadcasting on the same frequency?
What is the mac address of both routers?
