untangle openvpn
I am using an untangle firewall to create a site to site using open vpn. I have imported the site to site file but the connections fails. I am however able to connect with a client connections where I can ping the main office but they cannot ping my network in return. having a one way communication.
Can you give more details, e.g.
  • draw a figure to show your network typology, labelling your subnets
  • show how do you configure the vpn server, client etc.
  • show which routers and firmware you are using
I heard you added the remote site network to untangle openvpn export list and get this solved. Thanks for updating us.
