Unusual errors in VPN log
Hi, can anybody please tell me if my device is working okay after showing these errors. I installed the latest update yesterday and have been seeing lots of errors.
“Fri Sep 29 22:22:01 2023 daemon.notice netifd: wgclient (2099): * Running script ‘/etc/firewall.vpn_server_policy.sh’\nFri Sep 29 22:22:01 2023 daemon.notice netifd: wgclient (2099): Another app is currently holding the xtables lock. Perhaps you want to use the -w option?\nFri Sep 29 22:22:01 2023 daemon.notice netifd: wgclient (2099): Another app is currently holding the xtables lock. Perhaps you want to use the -w option?\nFri Sep 29 22:22:01 2023 daemon.notice netifd: wgclient (2099): Another app is currently holding the xtables lock. Perhaps you want to use the -w option?\nFri Sep 29 22:22:01 2023 daemon.notice netifd: wgclient (2099): Another app is currently holding the xtables lock. Perhaps you want to use the -w option?\nFri Sep 29 22:22:01 2023 daemon.notice netifd: wgclient (2099): Another app is currently holding the xtables lock. Perhaps you want to use the -w option?\nFri Sep 29 22:22:01 2023 daemon.notice netifd: wgclient (2099): Failed to parse json data: unexpected character\nFri Sep 29 22:22:01 2023 daemon.notice netifd: wgclient (2099): uci: Entry not found\nFri Sep 29 22:22:01 2023 daemon.notice netifd: Network device ‘wgclient’ link is down\nFri Sep 29 22:22:02 2023 daemon.notice netifd: wgclient (2099): sh: 1: unknown operand\nFri Sep 29 22:22:02 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()\nFri Sep 29 22:22:02 2023 daemon.notice netifd: Interface ‘wgclient’ is now down\nFri Sep 29 22:22:02 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now\nFri Sep 29 22:22:03 2023 daemon.notice netifd: wgclient (2678): RTNETLINK answers: Permission denied\nFri Sep 29 22:22:03 2023 daemon.notice netifd: Network device ‘wgclient’ link is up\nFri Sep 29 22:22:03 2023 daemon.notice netifd: Interface ‘wgclient’ is now up\nFri Sep 29 22:22:04 2023 user.notice mwan3[2985]: Execute ifup event on interface wgclient (wgclient)\nFri Sep 29 22:22:04 2023 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=3 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_9018 group_8336 group_1303 group_6555 peer_2001 peer_2002 peer_2003 peer_2004 peer_2005 peer_2006 peer_2007 peer_2008 peer_2009 peer_2010 peer_2011 peer_2012 peer_2013 peer_2014 peer_2015 peer_2016 peer_2017 peer_2018 peer_2019 peer_2020 peer_2021 peer_2022 peer_2023 peer_2024 peer_2025 peer_2026 peer_2027 peer_2028 peer_2029 peer_2030 peer_2031 pee\nFri Sep 29 22:22:04 2023 user.notice mwan3[2985]: Starting tracker on interface wgclient (wgclient)\nFri Sep 29 22:22:07 2023 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)\n”
I’m seeing something similar. Running WireGuard server on Brume 2 under ISP Modem and Slate AX for WireGuard client on different networks. Both are on Firmware 4.4.6.
I’ve had issues with port forwarding on the ISP modem before. Now I’m trying to figure out if it’s the ISP firewall.
These daemon.notice netifd: wgclient (2099): Another app is currently holding the xtables lock. Perhaps you want to use the -w option? errors are new though. Anyone have an idea of what it could be?
Here are my client logs when trying to connect:
Sun Dec 10 08:58:54 2023 daemon.notice netifd: wgclient (10598):  * Running script '/etc/firewall.vpn_server_policy.sh'
Sun Dec 10 08:58:54 2023 daemon.notice netifd: wgclient (10598): Another app is currently holding the xtables lock. Perhaps you want to use the -w option?
Sun Dec 10 08:58:54 2023 daemon.notice netifd: wgclient (10598):  * Running script '/var/etc/gls2s.include'
Sun Dec 10 08:58:54 2023 daemon.notice netifd: wgclient (10598):    ! Skipping due to path error: No such file or directory
Sun Dec 10 08:58:54 2023 daemon.notice netifd: wgclient (10598):  * Running script '/usr/bin/gl_block.sh'
Sun Dec 10 08:58:54 2023 daemon.notice netifd: wgclient (10598): uci: Entry not found
Sun Dec 10 08:58:54 2023 daemon.notice netifd: Network device 'wgclient' link is down
Sun Dec 10 08:58:54 2023 daemon.notice netifd: wgclient (10598): sh: 1: unknown operand
Sun Dec 10 08:58:55 2023 daemon.notice netifd: wgclient (10598): udhcpc: started, v1.33.2
Sun Dec 10 08:58:55 2023 daemon.notice netifd: wgclient (10598): udhcpc: sending discover
Sun Dec 10 08:58:55 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sun Dec 10 08:58:58 2023 daemon.notice netifd: wgclient (10598): udhcpc: no lease, failing
Sun Dec 10 08:58:58 2023 daemon.notice netifd: Interface 'wgclient' is now down
Sun Dec 10 08:58:58 2023 user.notice mwan3[11475]: Execute ifdown event on interface wgclient (unknown)
Sun Dec 10 08:58:59 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sun Dec 10 08:59:02 2023 daemon.notice netifd: Interface 'wgclient' is setting up now
