Update Settings
Firmware 2.257.
I have “auto-update” off yet am being prompted to install the new firmware, 2.26.
Surely unchecking the auto update box should stop all interaction with the update server? Otherwise, can I suggest another box “check for updates” which can be un-checked?
Glitch
you can check the script /usr/bin/glautoupdater
If no auto update, this script will exit directly.
The prompt of new version from UI will be available only if you use the UI. It cannot be disabled.
Yes, we thought about “check for update” option. We have this in another firmware but not yet released it.
