Currently running 4.6.4 and I'm trying to upgrade to 4.6.9.
Every time I try to apply the update, either using the default internet or local method it goes through the process and upon loading the admin page again it shows the same 4.6.4.
Internet via a wifi repeater config, OpenVPN client set to Block Non-VPN Traffic, AdGuard enabled.
I have tried this processes multiple times with and without the above VPN/AdGuard settings enabled, this has been preformed over wireless ie not connected to ethernet. I think the last time I did an upgrade I had to wipe the config first but I'd like to try to avoid that and figure out what I might be doing wrong.
