Hello!
This is my first time posting. I’m looking at purchasing the GL-X750 to run off either the AT&T or T-Mobile network near my house. I looked up the towers and found the primary bands for both are 2, 12, or 17 for both carriers.
I think it might be helpful to upgrade the antennas on the unit. I was looking at the following options:
-Linx ANT-LTE-MON-SMA
-Taoglas TG.35.8113W
Is there any issues with using those antennas? Do you have other recommendations?
Thanks in advance!
