The upload speed of several VPN’s is not going higher than 250mbps.
Any known issue?
Any known issue?
What vpn service?
What is the download speed?
What is the location you use and the loction of the vpn server?
Fixed, but how do you get higher vpn speeds? If i use my own connection and connect the wireguard on my Mac i get 700mbps. But on the router i only get 550 if i test in SSH. Whats the highest speed?
How do you test in ssh? iprerf3?
You should test on your pc.
But 550 is already a good number.
