Boot example:
AP121 (AR9331) U-Boot for DOMINO v1
DRAM: 64 MB DDR2 16-bit
FLASH: Winbond W25Q128 (16 MB)
CLOCKS: 400/400/200/33 MHz (CPU/RAM/AHB/SPI)
** Warning: bad env CRC, using default,
use ‘saveenv’ to save it in FLASH
LED on during eth initialization…
| __ \ / __ \ | / | |_ | | \ | | / __
|/ _/ || || |_____| || _| ____/
Hit any key to stop autobooting: 0
Device calibrated. Booting …
Booting image at: 0x9F050000
Image name: MIPS OpenWrt Linux-3.10.49
Created: 2015-06-17 7:07:46 UTC
Image type: MIPS Linux Kernel Image (lzma compressed)
Data size: 1114216 Bytes = 1.1 MB
Load address: 0x80060000
Entry point: 0x80060000
Uncompressing kernel image… OK!
Starting kernel…
[ 0.000000] Linux version 3.10.49 (alzhao@alzhao-ubuntu) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-
2014.04 r45620) ) #41 Wed Jun 17 15:07:32 HKT 2015
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Atheros AR9330 rev 1
[ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x03ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00000000-0x03ffffff]
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: board=DOMINO console=ttyATH0,115200 mtdparts=spi0.0:256k(u-boot)ro,64k
(u-boot-env)ro,16000k(firmware),64k(art)ro rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 61076k/65536k available (2386k kernel code, 4460k reserved, 620k data, 256k init, 0k
highmem)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.000000] Calibrating delay loop… 265.42 BogoMIPS (lpj=1327104)
[ 0.080000] pid_max: default: 32768 minimum: 301
[ 0.080000] Mount-cache hash table entries: 512
[ 0.090000] NET: Registered protocol family 16
[ 0.100000] MIPS: machine is Domino board
[ 0.550000] bio: create slab <bio-0> at 0
[ 0.560000] Switching to clocksource MIPS
[ 0.570000] NET: Registered protocol family 2
[ 0.570000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.570000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.570000] TCP: Hash tables configured (established 512 bind 512)
[ 0.580000] TCP: reno registered
[ 0.580000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.590000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.600000] NET: Registered protocol family 1
[ 0.620000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.630000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat,
Inc.
[ 0.640000] msgmni has been set to 119
[ 0.640000] io scheduler noop registered
[ 0.640000] io scheduler deadline registered (default)
[ 0.650000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.660000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART
[ 0.670000] console [ttyATH0] enabled, bootconsole disabled
[ 0.680000] ath79-spi ath79-spi: master is unqueued, this is deprecated
[ 0.690000] m25p80 spi0.0: found w25q128, expected m25p80
[ 0.690000] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.700000] 4 cmdlinepart partitions found on MTD device spi0.0
[ 0.710000] Creating 4 MTD partitions on “spi0.0”:
[ 0.710000] 0x000000000000-0x000000040000 : “u-boot”
[ 0.720000] 0x000000040000-0x000000050000 : “u-boot-env”
[ 0.720000] 0x000000050000-0x000000ff0000 : “firmware”
[ 0.740000] 2 uimage-fw partitions found on MTD device firmware
[ 0.750000] 0x000000050000-0x000000170000 : “kernel”
[ 0.750000] 0x000000170000-0x000000ff0000 : “rootfs”
[ 0.760000] mtd: device 4 (rootfs) set to be root filesystem
[ 0.760000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.770000] 0x000000930000-0x000000ff0000 : “rootfs_data”
[ 0.780000] 0x000000ff0000-0x000001000000 : “art”
[ 0.800000] libphy: ag71xx_mdio: probed
[ 1.350000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
[ 1.360000] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
[ 1.910000] ag71xx-mdio.1: Found an AR7240/AR9330 built-in switch
[ 2.950000] eth1: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
[ 2.960000] TCP: cubic registered
[ 2.960000] NET: Registered protocol family 17
[ 2.960000] Bridge firewalling registered
[ 2.970000] 8021q: 802.1Q VLAN Support v1.8
[ 2.980000] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[ 2.980000] Freeing unused kernel memory: 256K (80350000 - 80390000)
procd: Console is alive
procd: - watchdog -
[ 7.310000] usbcore: registered new interface driver usbfs
[ 7.320000] usbcore: registered new interface driver hub
[ 7.320000] usbcore: registered new device driver usb
[ 7.410000] SCSI subsystem initialized
[ 7.420000] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 7.420000] ehci-platform: EHCI generic platform driver
[ 7.430000] ehci-platform ehci-platform: EHCI Host Controller
[ 7.430000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[ 7.440000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 7.470000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 7.470000] hub 1-0:1.0: USB hub found
[ 7.470000] hub 1-0:1.0: 1 port detected
[ 7.480000] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 7.490000] uhci_hcd: USB Universal Host Controller Interface driver
[ 7.500000] usbcore: registered new interface driver usb-storage
procd: - preinit -
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 11.790000] jffs2: notice: (352) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of
xdatum (0 unchecked, 0 orphan) and 36 of xref (0 dead, 18 orphan) found.
[ 11.810000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[ 11.820000] block: unable to load configuration (fstab: Entry not found)
[ 11.820000] block: attempting to load /tmp/jffs_cfg/etc/config/fstab
[ 11.830000] block: extroot: not configured
jffs2 is ready
No jffs2 marker was found
[ 11.880000] jffs2: notice: (349) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of
[ 12.090000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[ 12.100000] block: unable to load configuration (fstab: Entry not found)
[ 12.100000] block: attempting to load /tmp/jffs_cfg/etc/config/fstab
[ 12.120000] block: extroot: not configured
switching to overlay
procd: - early -
procd: - watchdog -
/etc/init.d/mjpg-streamer: device ‘/dev/video0’ does not exist
procd: - ubus -
procd: - init -
Please press Enter to activate this console.
Command failed: Not found
[ 16.390000] NET: Registered protocol family 10
[ 16.440000] NTFS driver 2.1.30 [Flags: R/O MODULE].
[ 16.490000] loop: module loaded
[ 16.610000] nf_conntrack version 0.5.0 (958 buckets, 3832 max)
[ 16.640000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 16.670000] Linux video capture interface: v2.00
[ 16.710000] fuse init (API version 7.22)
[ 16.730000] usbcore: registered new interface driver cdc_acm
[ 16.730000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 16.740000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
[ 16.750000] Backport generated by backports.git backports-20140320-37-g5c33da0
[ 16.780000] gspca_main: v2.14.0 registered
[ 16.800000] usbcore: registered new interface driver sonixb
[ 16.800000] usbcore: registered new interface driver sonixj
[ 16.820000] usbcore: registered new interface driver gspca_zc3xx
[ 16.840000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 16.920000] usbcore: registered new interface driver usbserial
[ 16.920000] usbcore: registered new interface driver usbserial_generic
[ 16.930000] usbserial: USB Serial support registered for generic
[ 16.960000] usbcore: registered new interface driver uvcvideo
[ 16.960000] USB Video Class driver (1.1.1)
[ 17.000000] xt_time: kernel timezone is -0000
[ 17.020000] usbcore: registered new interface driver cdc_ether
[ 17.070000] cfg80211: Calling CRDA to update world regulatory domain
[ 17.070000] cfg80211: World regulatory domain updated:
[ 17.080000] cfg80211: DFS Master region: unset
[ 17.080000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 17.090000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 17.100000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 17.110000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 17.120000] cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
[ 17.120000] cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 17.130000] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 17.140000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 17.150000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 17.160000] usbcore: registered new interface driver cp210x
[ 17.160000] usbserial: USB Serial support registered for cp210x
[ 17.290000] PPP generic driver version 2.4.2
[ 17.290000] NET: Registered protocol family 24
[ 17.310000] usbcore: registered new interface driver rndis_host
[ 17.400000] usbcore: registered new interface driver option
[ 17.420000] usbserial: USB Serial support registered for GSM modem (1-port)
[ 17.590000] cfg80211: Calling CRDA for country: US
[ 17.600000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[ 17.640000] cfg80211: Regulatory domain changed to country: US
[ 17.640000] cfg80211: DFS Master region: FCC
[ 17.640000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 17.650000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 17.660000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm), (N/A)
[ 17.670000] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm), (0 s)
[ 17.680000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 17.690000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 32.640000] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 32.640000] device eth1 entered promiscuous mode
[ 32.650000] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 32.680000] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 37.320000] warning: `alljoyn-daemon’ uses 32-bit capabilities (legacy support in use)
procd: - init complete -
