for now i am using a new ar300m with usb tethering, wan as lan (for 2 LAN) & wifi off
I want to use a 4g dongle instead but i would like to know if it will be possible (& how obviously) to get sms from a ubuntu pc (through the app inbuilt in the modem or wammu).
maybe through ssh there is a way to launch a GUI in the modem or to make it available for wammu ?
hi & thx for your help, i could be blind but i cannot see it in the firmware (2.27) nor in luci (i am still usb tethering &i’d need to move the phone away high up for better reception while being able to see sms / miss calls while i’m working at the pc)
An app to install maybe ? i see there a few available, mainly asterisk & smstools3. asterisk looks like an overkill for my problem with some headeaches to configure + it is v11 available while the project has moved to 16.
would you look for me in your installed apps whether there is one containing sms ?
when it is using tethering you should get a IP from the Modem (look under gateway)
for example 192.168.0.1 just visit the Website from the modem and there you can read the SMS
