dq11
I tried stock openwrt 19.07.2
http://downloads.openwrt.org/releases/19.07.2/targets/ath79/generic/openwrt-19.07.2-ath79-generic-glinet_gl-x750-squashfs-sysupgrade.bin
Everything except the USB port seems to work. Same non-functional USB issue with Rooter GoldenORB(openwrt-GL-x750-GO2020-03-07-upgrade.bin)
I tried the GL-x750 3.102 firmware(which is based on openwrt-18.06.1) and the USB port works fine there
Any idea why the stock openwrt does not work? Is there a patch I can apply to the source code to make it work
Thanks in advance
dq11
2
I found this post in the openwrt forum USB on Gl-x750 - For Developers - OpenWrt Forum
echo 2 >/sys/class/gpio/export
echo out >/sys/class/gpio/gpio2/direction
That did the trick and I can access the usb now . How do we get this fixed upstream in a stock openwrt ?
Does GL-inet team have a procedure to relay fixes to the opensource project ?
I use stock openwrt on spitz with no USB issues
