I would like to connect two devices (apple TV + synology drive) on my GL-MT300A in repeater mode
The device on LAN is discoverable but not the one on WAN. Is it possible to convert the WAN to LAN ?
Yes. Just click “use as lan” in wan section.
Make sure you are using 3.x firmware.
the latest firmware for this device is 2.265
I checked on the website and there is no 3.x firmware for gl-mt300a
on a side note I tried installing 3.x on my GL-AR300M and it is now bricked…
https://dl.gl-inet.com/firmware/mt300a/testing/
Pls try 3.027 from the above. Don’t reserve setting if possible.
MT300A does not have Nand flash like AR300M which cause more problems.
That worked thank you
