Syslog contains multiple lines per minute that look like this:
Fri Aug 2 17:35:27 2019 user.err : can not found token file.
Any idea what it means?
Likely one of the GL.iNet binary-only packages as ‘can not found’ is not in the source beneath package
, feeds
, or target
@jeffsf really good as detective. I never read this carefully.
@kleinfelter this is like an error that token is expired. When you login the UI it will make a token. When token is expired you need to log in again.
