Using custom DNS whilst VPN Policy Based on the Target Domain or IP is configured
Thanks, I will try to upgrade and test later
edit: confirmed this works on a clean install of beta 3
Reported in Flint 2 (GL-MT6000 ) - bug reports - collective thread - #2179 by Pro4TLZZ
fixed in Flint 2 (GL-MT6000 ) - bug reports - collective thread - #2209 by hansome
Thanks for the report and confirming much appreciated.
Actually I did try the 4.6.0 snapshot 2024-06-18 18:04:32 (UTC+00:00) now.
Before I had just switched back to beta 3 4.6.0.
In the situation now the DNS leaks the same on both DNS Leak Test - BrowserLeaks & https://www.dnsleaktest.com/results.html.
cat vpnpolicy
config policy 'global'
	option kill_switch '0'
	option wan_access '0'
	option service_policy '1'
	option vpn_server_policy '1'
config service 'route_policy'
	option proxy_mode '3'
config policy 'vlan'
	option private '1'
	option guest '1'
config policy 'domain'
	option default_policy '0'
	option manual '1'
	option domain 'browserleaks.com
browserleaks.org
browserleaks.net'
cat adguardhome
config adguardhome 'config'
	option enabled '1'
	option dns_enabled '0'
Maybe this is a separate snapshot bug? Is there a way to test the op24 with the snapshot fix?
Either way I shall return to beta 3 4.6.0 for now and hope that gets released soon
@hansome
