Using the GL.iNET App when Flint 3 is in Access Point Mode
I have the Flint 3 Wi-Fi 7 router configured in access point mode so that it can connect to my existing router. I can access the Flint 3 in the browser by typing in the IP address assigned by the DHCP of my existing router. I discovered in order for the GL.iNET App to access the Flint 3 on my phone, it is necessary to create a GoodCloud user AC and bind the Flint 3 to the user AC. If you try to add the Flint 3 following the normal steps, the App will not be able to find the Flint 3 because it is looking for the Flint 3 default IP address: 192.168.8.1 and gets stuck.
Please refer to the following tutorial to manually configure Flint 3's WAN IP address so that the app can connect to it.
Add Brume 2 into mobile App - GL.iNet Router Docs 4
Thank you for your advice! I see that it is also possible to add a device by clicking the “Initialized Devices” button and entering the changed Flint 3 IP address.
