OK. We decided to add a dumb option or message in the UI telling the user that if you enable vpn then all your data has to go through vpn, i.e. VPN kill switch or block connection if no vpn.
@alzhao This help dumb people like me but is not really what is problems.
Please I try explain again.
Problem is maybe someone having traffic that NO CAN happen without VPN. Maybe is use tor browser in country where is not allowing use tor.
Problem is three.
First is wonder “is connection happen over VPN or no?” Put text in GUI not really confirm nothings, just say.
Second problems is when I must “Abort” VPN for reason VPN is no connect. Is good have option that NEVER GL will pass internet to client when not VPN is connected.
Third problem is when must “Change server.” I wondering if this is case where there is few seconds where no VPN exist?
One question, in this case, do you care about the router itself has data leak or not? If you care about it, so the router would never can connect to VPN server.
