Hello Dear Forum,
i recently bought a Flint 2 Router to use in combination with the Allnet All-bm100VDSL2V Modem. I just moved and chose NetCologne as a provider, using VDSL. I have configured the Modem in Bridge Mode and used PPPoE with the Username and Password my provider provided as well as the required VLAN-Tag. After trying to connect for around 20-30 seconds the process gets discarded and then starts anew. I have talked with my provider and on their system all of the connection attempts have been marked as successful, so the dialing has worked as intended using PPPoE. I have not put in the authentications nor the Vland-Tag into the modem directly, so the transmission from the Router must work.
So there seems to be a problem with the handshake between the router and the modem.
I have tried both wan ports on the router with no success, putting a network switch between the router and the modem as well as reducing MTU to 1480, all of which did not impact the process.
I know the Modem is pretty old and buying a good modern one (like the DrayTek Vigor167) would fix it, but if anyone has an idea how to get it to work with the Allnet modem i would really appreciate it
(ps: I only have a 100mbit line anyway, so the modem is enough for my needs, if i get it to work).
Thanks in advance to anyone taking time to read or reply to this post, i wish you a great rest of the day.
Here are the Logs of the Flint 2, running Firmware version 4.11.0:
Thu Oct 1 23:38:49 2026 daemon.notice netifd: Interface 'secondwan' is now down
Thu Oct 1 23:38:49 2026 kern.info kernel: [179065.809208] mt7530 mdio-bus:1f lan1: Link is Down
Thu Oct 1 23:38:49 2026 daemon.info avahi-daemon[10106]: Interface lan1.IPv6 no longer relevant for mDNS.
Thu Oct 1 23:38:49 2026 daemon.info avahi-daemon[10106]: Leaving mDNS multicast group on interface lan1.IPv6 with address fe80::9683:c4ff:feda:abfa.
Thu Oct 1 23:38:49 2026 daemon.info avahi-daemon[10106]: Withdrawing address record for fe80::9683:c4ff:feda:abfa on lan1.
Thu Oct 1 23:38:49 2026 daemon.notice netifd: Interface 'secondwan' is disabled
Thu Oct 1 23:38:49 2026 kern.info kernel: [179065.823085] mt7530 mdio-bus:1f lan1: configuring for phy/sgmii link mode
Thu Oct 1 23:38:49 2026 kern.info kernel: [179065.830181] 8021q: adding VLAN 0 to HW filter on device lan1
Thu Oct 1 23:38:49 2026 daemon.notice netifd: Interface 'secondwan' is enabled
Thu Oct 1 23:38:49 2026 daemon.notice netifd: Interface 'secondwan' is setting up now
Thu Oct 1 23:38:49 2026 daemon.notice netifd: VLAN 'lan1.7' link is down
Thu Oct 1 23:38:49 2026 daemon.notice netifd: Interface 'secondwan' has link connectivity loss
Thu Oct 1 23:38:49 2026 daemon.notice netifd: Network device 'lan1' link is down
Thu Oct 1 23:38:49 2026 kern.info kernel: [179065.922556] mt7530 mdio-bus:1f lan1: configuring for phy/sgmii link mode
Thu Oct 1 23:38:49 2026 kern.info kernel: [179065.929677] 8021q: adding VLAN 0 to HW filter on device lan1
Thu Oct 1 23:38:50 2026 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "secondwan" ] } }
Thu Oct 1 23:38:50 2026 user.notice firewall: Reloading firewall due to ifdown of secondwan ()
Thu Oct 1 23:38:50 2026 daemon.info dnsmasq[16366]: read /etc/hosts - 12 names
Thu Oct 1 23:38:50 2026 daemon.info dnsmasq[16366]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Thu Oct 1 23:38:50 2026 daemon.info dnsmasq-dhcp[16366]: read /etc/ethers - 0 addresses
Thu Oct 1 23:38:52 2026 kern.info kernel: [179068.316339] mt7530 mdio-bus:1f lan1: Link is Up - 1Gbps/Full - flow control rx/tx
Thu Oct 1 23:38:52 2026 kern.info kernel: [179068.323936] IPv6: ADDRCONF(NETDEV_CHANGE): lan1: link becomes ready
Thu Oct 1 23:38:52 2026 daemon.notice netifd: Network device 'lan1' link is up
Thu Oct 1 23:38:52 2026 daemon.notice netifd: VLAN 'lan1.7' link is up
Thu Oct 1 23:38:52 2026 daemon.notice netifd: Interface 'secondwan' has link connectivity
Thu Oct 1 23:38:52 2026 daemon.notice netifd: Interface 'secondwan' is setting up now
Thu Oct 1 23:38:53 2026 daemon.info avahi-daemon[10106]: Joining mDNS multicast group on interface lan1.IPv6 with address fe80::9683:c4ff:feda:abfa.
Thu Oct 1 23:38:53 2026 daemon.info avahi-daemon[10106]: New relevant interface lan1.IPv6 for mDNS.
Thu Oct 1 23:38:53 2026 daemon.info avahi-daemon[10106]: Registering new address record for fe80::9683:c4ff:feda:abfa on lan1.*.
Thu Oct 1 23:39:22 2026 daemon.err insmod: module is already loaded - slhc
Thu Oct 1 23:39:22 2026 daemon.err insmod: module is already loaded - ppp_generic
Thu Oct 1 23:39:22 2026 daemon.err insmod: module is already loaded - pppox
Thu Oct 1 23:39:22 2026 daemon.err insmod: module is already loaded - pppoe
Thu Oct 1 23:39:22 2026 daemon.info pppd[7739]: Plugin rp-pppoe.so loaded.
Thu Oct 1 23:39:22 2026 daemon.info pppd[7739]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Thu Oct 1 23:39:22 2026 daemon.notice pppd[7739]: pppd 2.4.8 started by root, uid 0
Thu Oct 1 23:39:37 2026 daemon.warn pppd[7739]: Timeout waiting for PADO packets
Thu Oct 1 23:39:37 2026 daemon.err pppd[7739]: Unable to complete PPPoE Discovery
Thu Oct 1 23:39:37 2026 daemon.info pppd[7739]: Exit.
