Am I part of the velica B1500 pre B2200 beta test? Doesn’t seem to be an option on web interface or the app (local or cloud) for mesh options just wifi settings like ar750s etc
Ironic the box being a 2 pack specifically for mesh…
firmware 3.107.
firmware 3.107.
Eventually sorted there is a new app.
Can’t it be added as an option as default in the web interface?
As long as one way works, hope you can keep using it.
