Velica GL-B2200 dropping WAN connection every single hour
I recently got my Velica(GL-B2200) Mesh Router. I am facing an issue right now where it keeps on dropping the WAN connection then automatically reconnects within few seconds. This happens exactly every hour and during this time the Wifi is not available for about 1 minute. This problem is very annoying. The firmware version right now is latest: 3.105 - compile time: 2020-12-30 21:56:23.
I have never faced this issue on my old router from Netgear which I have been using for more than 4 years with my same ISP.
I think this happens every time with a DHCP lease renewal. Whenever there is a DHCP lease renewal the connection seems to be dropped even though the WAN IP address has not been changed.
Possible scripts to look are maybe these?:
/lib/netifd/proto/dhcp.sh
/usr/share/udhcpc/default.script
I have attached the snippet of the log from the time when this had happened. Some help would be greatly appreciated!.
Sun Feb 14 15:56:31 2021 daemon.notice netifd: wan (1852): udhcpc: sending renew
Sun Feb 14 15:56:31 2021 daemon.notice netifd: wan (1852): udhcpc: lease of <WAN_IP> obtained, lease time 7200
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82834.872993] STOPPED EVENT for vap 0 (dd54e000)
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82834.876661] send_vdev_down_cmd_non_tlv for vap 0
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82834.906060] OL vap_start +
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82834.907753] VDEV START
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82834.910093] OL vap_start -
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82834.912852] ol_vdev_start_resp_ev for vap 0 (dd54e000)
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82834.913018] su bfee 1 mu bfee 0 su bfer 1 mu bfer 1 impl bf 0 sounding dim 1
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82834.913040] send_vdev_up_cmd_non_tlv for vap 0
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82834.913068] Beacon mode set to staggered. Cannot enable FD
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82834.913074] __ieee80211_smart_ant_init: Smart Antenna is not supported
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82834.941588] ol_ath_vap_set_param: Now supported MGMT RATE is 1000(kbps) and rate code: 0x43
Sun Feb 14 15:56:33 2021 daemon.notice netifd: Network device 'ath0' link is down
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82834.986248] STOPPED EVENT for vap 0 (dd54e000)
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82834.989899] send_vdev_down_cmd_non_tlv for vap 0
Sun Feb 14 15:56:33 2021 kern.info kernel: [82834.995684] br-lan: port 2(ath0) entered disabled state
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82835.111562] send_vdev_delete_cmd_non_tlv for vap 0
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82835.115364] ol_ath_vap_delete: wmi_unified_vdev_delete_send done ID = 0 vap (d3950000) VAP Addr = 94:83:c4:0d:3d:93:
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82835.125937] ieee80211_mbo_vdetach: MBO terminated
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82835.130525] ieee80211_oce_vdetach: OCE terminated
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82835.135290] Suspending Target  scn=da080500
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82835.139425] waiting for target paused event from target
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82835.144674] ol_ath_thermal_mitigation_detach: ++
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82835.149365] ol_ath_thermal_mitigation_detach: --
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82835.154085] ol_if_dfs_clist_update: called, cmd=1, nollist=  (null), nentries=0
Sun Feb 14 15:56:33 2021 kern.alert kernel: [82835.162934] HTC TX lookup failed!
Sun Feb 14 15:56:33 2021 kern.alert kernel: [82835.165232] HTC TX lookup failed!
Sun Feb 14 15:56:33 2021 kern.alert kernel: [82835.168853] HTC TX lookup failed!
Sun Feb 14 15:56:33 2021 kern.alert kernel: [82835.171828] HTC TX lookup failed!
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82835.176685] ce_h2t_tx_ce_cleanup 1039 Fastpath mode ON, Cleaning up HTT Tx CEDisabling Mcastenhance. This may take some time...
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82835.216292] Reset complete for wifi core id : 0
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82835.219832] hif_disable: Xhif_napi_destroy: NAPI 6 destroyed
Sun Feb 14 15:56:33 2021 kern.warn kernel: [82835.225440] hif_napi_destroy: no NAPI instances. Zapped.ath_sysfs_diag_fini: diag_fsattr
Sun Feb 14 15:56:33 2021 kern.info kernel: [82835.238652] br-lan: port 2(ath0) entered disabled state
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.407727] STOPPED EVENT for vap 0 (d9ee6000)
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.411281] send_vdev_down_cmd_non_tlv for vap 0
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.435987] OL vap_start +
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.437690] VDEV START
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.440027] OL vap_start -
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.440281] ol_vdev_start_resp_ev for vap 0 (d9ee6000)
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.440449] su bfee 1 mu bfee 0 su bfer 1 mu bfer 1 impl bf 0 sounding dim 1
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.440482] send_vdev_up_cmd_non_tlv for vap 0
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.440508] Beacon mode set to staggered. Cannot enable FD
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.440514] __ieee80211_smart_ant_init: Smart Antenna is not supported
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.471481] ol_ath_vap_set_param: Now supported MGMT RATE is 6000(kbps) and rate code: 0x3
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.520139] STOPPED EVENT for vap 0 (d9ee6000)
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.523620] send_vdev_down_cmd_non_tlv for vap 0
Sun Feb 14 15:56:34 2021 daemon.notice netifd: Network device 'ath1' link is down
Sun Feb 14 15:56:34 2021 kern.info kernel: [82835.547231] br-lan: port 3(ath1) entered disabled state
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.661588] send_vdev_delete_cmd_non_tlv for vap 0
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.665480] ol_ath_vap_delete: wmi_unified_vdev_delete_send done ID = 0 vap (d4830000) VAP Addr = 94:83:c4:0d:3d:94:
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.676181] ieee80211_mbo_vdetach: MBO terminated
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.680558] ieee80211_oce_vdetach: OCE terminated
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.685397] Suspending Target  scn=d9bc0500
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.689672] waiting for target paused event from target
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.694809] ol_ath_thermal_mitigation_detach: ++
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.699608] ol_ath_thermal_mitigation_detach: --
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.703939] ol_if_dfs_clist_update: called, cmd=1, nollist=  (null), nentries=0
Sun Feb 14 15:56:34 2021 kern.alert kernel: [82835.712967] HTC TX lookup failed!
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.717707] ce_h2t_tx_ce_cleanup 1039 Fastpath mode ON, Cleaning up HTT Tx CEDisabling Mcastenhance. This may take some time...
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.760828] Reset complete for wifi core id : 1
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.764461] hif_disable: Xhif_napi_destroy: NAPI 6 destroyed
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.770073] hif_napi_destroy: no NAPI instances. Zapped.ath_sysfs_diag_fini: diag_fsattr
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.778339] channel is not 2.4G return faile
Sun Feb 14 15:56:34 2021 kern.info kernel: [82835.788453] br-lan: port 3(ath1) entered disabled state
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.950870] STOPPED EVENT for vap 0 (d951e000)
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.954366] send_vdev_down_cmd_non_tlv for vap 0
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.976063] OL vap_start +
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.977759] VDEV START
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.980097] OL vap_start -
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.980360] ol_vdev_start_resp_ev for vap 0 (d951e000)
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.980518] su bfee 1 mu bfee 0 su bfer 1 mu bfer 1 impl bf 0 sounding dim 1
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.980540] send_vdev_up_cmd_non_tlv for vap 0
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.980568] Beacon mode set to staggered. Cannot enable FD
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82835.980575] __ieee80211_smart_ant_init: Smart Antenna is not supported
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82836.011543] ol_ath_vap_set_param: Now supported MGMT RATE is 6000(kbps) and rate code: 0x3
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82836.056403] STOPPED EVENT for vap 0 (d951e000)
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82836.059877] send_vdev_down_cmd_non_tlv for vap 0
Sun Feb 14 15:56:34 2021 daemon.notice netifd: Network device 'ath2' link is down
Sun Feb 14 15:56:34 2021 kern.info kernel: [82836.088247] br-lan: port 4(ath2) entered disabled state
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82836.260114] send_vdev_delete_cmd_non_tlv for vap 0
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82836.264050] ol_ath_vap_delete: wmi_unified_vdev_delete_send done ID = 0 vap (d3948000) VAP Addr = 94:83:c4:0d:3d:95:
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82836.274818] ieee80211_mbo_vdetach: MBO terminated
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82836.279389] ieee80211_oce_vdetach: OCE terminated
Sun Feb 14 15:56:34 2021 kern.warn kernel: [82836.283999] Suspending Target  scn=d8640500
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.288263] waiting for target paused event from target
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.293230] ol_ath_thermal_mitigation_detach: ++
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.298243] ol_ath_thermal_mitigation_detach: --
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.302493] ol_if_dfs_clist_update: called, cmd=1, nollist=  (null), nentries=0
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.317103] ce_h2t_tx_ce_cleanup 1039 Fastpath mode ON, Cleaning up HTT Tx CEDisabling Mcastenhance. This may take some time...
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.332807] hif_pci_device_reset: Reset Devicehif_pci_disable_bus: Xhif_disable: Xhif_napi_destroy: NAPI 6 destroyed
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.343609] hif_napi_destroy: no NAPI instances. Zapped.ath_sysfs_diag_fini: diag_fsattr
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.351770] channel is not 2.4G return faile
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.363069] br-lan: port 4(ath2) entered disabled state
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.627496] [ol_ath_iw_setcountry][1832] *p=55, *(p+1)=53
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.631910]  *********** IPQ4019  *************Wifi0 CPU frequency 250000000
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.658962] hif_target_sync_ahb: Got FW signal, retries = 1hif_ahb_enable_bus: X - hif_type = 0xd, target_type = 0xbhif_config_ce: ce_init donehif_config_ce: X, ret = 0hif_set_hia: Ehif_pci_bus_configure: hif_set_hia donehif_configure_irq: Ehif_enable: X OKhif_napi_create: NAPI structures initializedhif_napi_create: NAPI id 6 created for pipe 5qca_napi_create: napi instance 32 created on pipe 4
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.697228] hif_napi_event: received evnt: CONF cmd; v = 1 (state=0x1)hif_napi_event: setting configuration to ON
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.707633] ol_target_init() BMI inited.
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.711401] ol_target_init() BMI Get Target Info.
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.716171] Chip id: 0xb, chip version: 0x1000000
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.720653]
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.720653]  CE WAR Disabled
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.725128] NUM_DEV=1 FWMODE=0x2 FWSUBMODE=0x0 FWBR_BUF 0
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.730615] ol_target_init() configure Target .
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.734974]
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.734974]  Target Version is 1000000
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.740128]
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.740128]  Flash Download Address  c0000
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.745740] ol_transfer_bin_file: flash data file defined
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.751156] ol_transfer_bin_file[3773] Get Caldata for wifi0.
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.756923] qdf_fs_read[59], Open File /tmp/wifi0.caldata SUCCESS!!file system magic:16914836super blocksize:4096inode 1076file size:12064qc98xx_verify_checksum: flash checksum passed: 0x89ea
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.773868] ol_transfer_bin_file 3834: Download Flash data len 12064
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.780598] Board extended Data download address: 0x0
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.804792]
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.804792]  Board data initialized
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.808820] ol_ath_download_firmware: Download OTP, flash download ADDRESS 0xc0000
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.816314]
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.816314]  Selecting  OTP binary for CHIP Version -1063631476
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.823836] ol_transfer_bin_file 3654: downloading file 0, Download data len 4680
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.847568]
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.847568]  First OTP send param 8000
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.856430] ol_ath_download_firmware :First OTP download and Execute is good address:0x5000 return param 4660
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.865307] ol_ath_download_firmware:##Board Id 20 , CHIP Id 0
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.871249] ol_ath_download_firmware: BOARDDATA DOWNLOAD TO address 0xc0000
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.878108]
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.878108]  wifi0: Selecting board data file name boardData_1_0_IPQ4019_DK04_2G.bin
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.887294] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=IPQ4019/hw.1/boardData_1_0_IPQ4019_DK04_2G.bin
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.899478] ol_transfer_bin_file 3654: downloading file 3, Download data len 12064
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.907270] Board extended Data download address: 0x0
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.931662] ol_ath_download_firmware: Using 0x1234 for the remainder of init
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.937705]
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.937705]  Selecting  OTP binary for CHIP Version -1063631476
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.945187] ol_transfer_bin_file 3654: downloading file 0, Download data len 4680
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.968932]
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.968932]  [Flash] : Ignore Module param
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.973475]
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.973475]  Second otp download Param 10000
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82836.989590] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.996840]
Sun Feb 14 15:56:35 2021 kern.info kernel: [82836.996840]  Mission mode: Firmware CHIP Version -1063631476
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82837.004418] ol_swap_wlan_memory_expansion: length:165455 size_left:165475 dma_size_left:262144 fw_temp:e4581004 fw_entry_size:165479
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82837.015885] ol_swap_wlan_memory_expansion: dma_virt_addr :e14e1000 fw_temp: e4581008 length: 165455
Sun Feb 14 15:56:35 2021 kern.info kernel: [82837.025056] Swap: bytes_left to copy: fw:16; dma_page:96689
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82837.030454] ol_swap_wlan_memory_expansion: length:0 size_left:12 dma_size_left:96689 fw_temp:e45a965b fw_entry_size:165479
Sun Feb 14 15:56:35 2021 kern.info kernel: [82837.041459] Swap: wrong length read:0
Sun Feb 14 15:56:35 2021 kern.info kernel: [82837.045085] ol_swap_wlan_memory_expansion: Swap total_bytes copied: 165455 Target address 417b70
Sun Feb 14 15:56:35 2021 kern.info kernel: [82837.054071] scn=da080500  target_write_addr=417b70 seg_info=de113810
Sun Feb 14 15:56:35 2021 kern.info kernel: [82837.060393] ol_transfer_swap_struct:Code swap structure successfully downloaded for bin type =2
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82837.069148] bin_filename=IPQ4019/hw.1/athwlan.bin swap_filename=/lib/firmware/IPQ4019/hw.1/athwlan.codeswap.bin
Sun Feb 14 15:56:35 2021 kern.warn kernel: [82837.079342] ol_transfer_bin_file: Downloading firmware file: IPQ4019/hw.1/athwlan.bin
Sun Feb 14 15:56:35 2021 kern.info kernel: [82837.087883] ol_transfer_bin_file 3654: downloading file 1, Download data len 372480
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.341470] ol_target_init() Download FW done.
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.345149]
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.345149] ol_ath_copy_tgt_iram() iram read paddr: 0x980000 host paddr 0x87500000 Radio id 0
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.520100] +htc_create ..  HIF :d5a68000-htc_create: (0xda837800)
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.525076] htc_wmi_init() HT Create . da837800
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.529861] htc_wmi_init 7754 host_enable 0 nss_nwifi_offload 0
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.535667] ol_ath_set_default_tgt_config : AC Minfree buffer allocation through module param (umac.ko)
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.545063]  OL_ACBKMinfree : 0
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.548182]  OL_ACBEMinfree : 0
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.551287]  OL_ACVIMinfree : 0
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.554410]  OL_ACVOMinfree : 0
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.557557] hif_enable_fastpath, Enabling fastpath mode
Sun Feb 14 15:56:37 2021 kern.alert kernel: [82838.562572] +HWT
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.564575] hif_completion_thread_startup: pipe_num:0 pipe_info:0xd5a6cb78hif_completion_thread_startup: pipe_num:3 pipe_info:0xd5a6cc50hif_completion_thread_startup: pipe_num:4 pipe_info:0xd5a6cc98
Sun Feb 14 15:56:37 2021 kern.alert kernel: [82838.585537] -HWT
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.586550] wmi_unified_register_event_handler : event handler already registered 0x8002
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.594649] Startup Mode-0 set
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.597655] pdev attach   (null) -1
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.601180]
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.601180] <=== cfg max peer id 1056 ====>
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.607279] htt_peer_map_timer_init Enter pdev d6060000 hrtimer d6064948
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.613514]
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.613514]  htt_alloc_peer_map_mem : Alloc Success : host q vaddr d8d42000 paddr 98d42000
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.623269]
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.623269]  htt_alloc_peer_map_mem : Flush Interval Configured to 256 pkts
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.633814] ol_txrx_pdev_attach: 2500 tx desc's allocated ; range starts from d8480000
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.642880] Firmware_Build_Number:7
Sun Feb 14 15:56:37 2021 kern.alert kernel: [82838.645432] host/RAM_fw Build Ver Mismatch: H:0x32, F:0x7 !
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.651276] FW wireless modes: 0x680c
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.654718] num_rf_chain:0x00000002  ht_cap_info:0x0000085b  vht_cap_info:0x339959b2  vht_supp_mcs:0x0000fffa
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.664622] btcoex_support 0, wlan_prio_gpio 0, coex_gpio_pin 0 0 0
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.671008] wmi_service_coex_gpio 1, wmi_service_4_wire_coex_support 1, coex_version 0
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.678866]
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.678866] Sending Ext resource cfg: HOST PLATFORM as 0
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.678866] fw_feature_bitmap as 50 to TGT
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.689799] ol_ath_service_ready_event: tt_support: 1
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.694647] ol_ath_service_ready_event: periodic_chan_stats: 1
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.700603] ol_ath_service_ready_event: sw_cal_support_check_flag: 1
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.706896] Peer Caching Enabled ; num_peers = 530, num_active_peers = 52 num_tids = 104, num_vdevs = 17
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.716419] EXT NSS Supported
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.719227] idx 1 req 2  num_units 1 num_unit_info 12 unit size 256 actual units 53
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.727077] ol_ath_alloc_host_mem_chunk req_id 2 idx 0 num_units 53 unit_len 256,
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.736019] idx 2 req 3  num_units 1 num_unit_info 12 unit size 1024 actual units 53
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.742822] ol_ath_alloc_host_mem_chunk req_id 3 idx 1 num_units 53 unit_len 1024,
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.750405] idx 3 req 4  num_units 1 num_unit_info 12 unit size 4096 actual units 53
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.758211] ol_ath_alloc_host_mem_chunk req_id 4 idx 2 num_units 53 unit_len 4096,
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.765736] idx 0 req 1  num_units 0 num_unit_info 2 unit size 744 actual units 531
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.773601] ol_ath_alloc_host_mem_chunk req_id 1 idx 3 num_units 531 unit_len 744,
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.781052] idx 4 req 6  num_units 35 num_unit_info 0 unit size 3072 actual units 35
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.788850] ol_ath_alloc_host_mem_chunk req_id 6 idx 4 num_units 35 unit_len 3072,
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.796400] idx 5 req 7  num_units 1 num_unit_info 0 unit size 6144 actual units 1
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.804015] ol_ath_alloc_host_mem_chunk req_id 7 idx 5 num_units 1 unit_len 6144,
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.811502] idx 6 req 5  num_units 0 num_unit_info 2 unit size 2028 actual units 531
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.819328] ol_ath_alloc_host_mem_chunk req_id 5 idx 6 num_units 531 unit_len 2028,
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.826986] Support not added yet for Service 91
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.831530] Support not added yet for Service 92
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.836151] No EXT_MSG send INIT now
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.839700] chunk 0 len 13568 requested , ptr  0x9ba24000
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.845070] chunk 1 len 54272 requested , ptr  0x99b40000
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.850480] chunk 2 len 217088 requested , ptr  0x99b80000
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.855944] chunk 3 len 395064 requested , ptr  0x99400000
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.861390] chunk 4 len 107520 requested , ptr  0x99b60000
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.866883] chunk 5 len 6144 requested , ptr  0x9a922000
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.872154] chunk 6 len 1076868 requested , ptr  0x99600000
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.877812] ol_ath_service_ready_event[4251] WAPI MBSSID 2
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.883416] smart_log_init: Smart logging Enabled buf=d6f50000 (size=65536)
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.920432] Version = 16777216 3  status = 0
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.923706] ol_ath_connect_htc() WMI is ready
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.928097] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 0
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.928112] target uses HTT version 2.2; host uses 2.2
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.947977] wmi_unified_register_event_handler : event handler already registered 0x900b
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.955040] wmi_unified_register_event_handler : event handler already registered 0x9042
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.963123] >>>> CB Set   (null)
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.966461] ol_ath_thermal_mitigation_attach: --
Sun Feb 14 15:56:37 2021 kern.debug kernel: [82838.970924] ol_if_dfs_setup: called
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.970952] ath_sysfs_diag_init: diag_fsattr
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82838.975283] isCountryCodeValid: EEPROM regdomain 0x0
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.980257] ol_regdmn_init_channels: !avail mode 0x680c (0x2) flags 0x2150
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.987092] ol_regdmn_init_channels: !avail mode 0x680c (0x1) flags 0x140
Sun Feb 14 15:56:37 2021 kern.info kernel: [82838.993873] ol_regdmn_init_channels: !avail mode 0x680c (0x20) flags 0xd0
Sun Feb 14 15:56:37 2021 kern.info kernel: [82839.000630] ol_regdmn_init_channels: !avail mode 0x680c (0x40) flags 0x150
Sun Feb 14 15:56:37 2021 kern.info kernel: [82839.007524] ol_regdmn_init_channels: !avail mode 0x680c (0x1000) flags 0x10100
Sun Feb 14 15:56:37 2021 kern.info kernel: [82839.014674] ol_regdmn_init_channels: !avail mode 0x680c (0x8000) flags 0x20100
Sun Feb 14 15:56:37 2021 kern.info kernel: [82839.021895] ol_regdmn_init_channels: !avail mode 0x680c (0x10000) flags 0x40100
Sun Feb 14 15:56:37 2021 kern.info kernel: [82839.029184] ol_regdmn_init_channels: !avail mode 0x680c (0x20000) flags 0x100100
Sun Feb 14 15:56:37 2021 kern.info kernel: [82839.036563] ol_regdmn_init_channels: !avail mode 0x680c (0x40000) flags 0x200100
Sun Feb 14 15:56:37 2021 kern.info kernel: [82839.043926] ol_regdmn_init_channels: !avail mode 0x680c (0x80000) flags 0x400100
Sun Feb 14 15:56:37 2021 kern.info kernel: [82839.051322] ol_regdmn_init_channels: !avail mode 0x680c (0x100000) flags 0x800100
Sun Feb 14 15:56:37 2021 kern.info kernel: [82839.058786] ol_regdmn_init_channels: !avail mode 0x680c (0x200000) flags 0x4000100
Sun Feb 14 15:56:37 2021 kern.info kernel: [82839.066338] ol_regdmn_init_channels: !avail mode 0x680c (0x400000) flags 0x8000100
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82839.097248] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg00000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000, cfgvalid[2] 10000
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82839.115829] smart_log_deinit: Smart logging Disabled
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82839.149749] set TXBF_SND_PERIOD: value 100 wmi_status 0
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82839.179659]  Disconnect_timeout value entered:10
Sun Feb 14 15:56:37 2021 kern.warn kernel: [82839.188855]  reconfiguration_timeout value entered:60
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82839.625735] send_vdev_create_cmd_non_tlv: ID = 0 Type = 1, Subtype = 0 VAP Addr = 94:83:c4:0d:3d:93:
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82839.634467] ieee80211_mbo_vattach:MBO Initialized
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82839.639355] ieee80211_oce_vattach: OCE Initialized
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82839.644054] __ieee80211_smart_ant_init: Smart Antenna is not supported
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82839.650926] Enabling TX checksum bit for the vap ath0 features 4000
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82839.657626] Enabling SG bit for the vap ath0 features 4000
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82839.662358] Enabling SG bit for the vap ath0 features 4000
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82839.668778] Enabling TSO bit for the vap ath0 features 4000
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82839.673502] Enabling LRO bit for the vap ath0 features 4000
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82839.684149] VAP device ath0 created osifp: (d9c53500) os_if: (d8cf8000)
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82839.734289] siwfreq
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82839.735442] Set freq vap 0 stop send + d8cf8000
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82839.740803] Set freq vap 0 stop send -d8cf8000
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82839.766275] Set wait done --d8cf8000
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82840.067159] [DEBUG] vap-0(ath0):set SIOC80211NWID, 8 characters
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82840.072112]
Sun Feb 14 15:56:38 2021 kern.warn kernel: [82840.072112]  DES SSID SET=Wormhole
Sun Feb 14 15:56:39 2021 kern.warn kernel: [82840.765942]  ieee80211_ioctl_siwmode: imr.ifm_active=131712, new mode=3, valid=1
Sun Feb 14 15:56:39 2021 kern.warn kernel: [82840.816404]  DEVICE IS DOWN ifname=ath0
Sun Feb 14 15:56:39 2021 kern.warn kernel: [82840.819315]  DEVICE IS DOWN ifname=ath0
Sun Feb 14 15:56:39 2021 kern.warn kernel: [82841.056195] Sending SCAN START cmd
Sun Feb 14 15:56:39 2021 kern.info kernel: [82841.058747] 8021q: adding VLAN 0 to HW filter on device ath0
Sun Feb 14 15:56:40 2021 daemon.notice netifd: Network device 'ath0' link is up
For now I have what I have done is connected my old Netgear router back to my Verizon WAN ethernet connection and then I have connected Velica router via the lan port. In this mode I can use Velica without any issues. Netgear router is able to retain seamless connection to my ISP and share the same with Velica router via lan connection. This further helps confirm that there is definitely something wrong in the way Velica handles DHCP lease renewal. I have also called my ISP regarding this issue but they also pretty came to the same conclusion with the new router causing this and not them.
Would appreciate some help on this. Thank you in advance!
I forwarded to developer to check.
Have you enabled router policy?
No I had not setup and routing policy I believe. The only policy that I have is VPN policy but I think that would not be related to this issue.
Please pm me your email I’d like to send you a test firmware.
@hansome Thank you for this. Can you please PM me?. Sorry I am new to this forum and I am unable to find any option to send a PM. Seems like it is not enabled for me. I kept on searching for this option but no luck.
Hi Niket,
Replied you on our support@gl-inet.com with the testing firmware. Hansome already issued a firmware to fix this bug.
Hi @simonli & @hansome - just closing out this thread here. The test firmware seems to fix this issue. My Wifi no longer drops the connection with WAN each time when it does a DHCP lease renewal. Thank you for the quick turnaround from the team. Really appreciate it!.
