VPN from Iran - blocked access
There it is. So that’s my mistake. The proper find command would be find /tmp -iname parted* . The ‘start’ is important; it tells the find command to find anything with parted beginning in the file name.
cd ..; find /tmp -iname parted*     & try it for yourself. Let’s make sure I’ve not gone completely crazy.
root@GL-MT6000:~# cd ..; find /tmp -iname parted*
/tmp/owrt_-_flint-v2_-_usb_ipks/parted_3.6-1_aarch64_cortex-a53.ipk
root@GL-MT6000:/#
cd /tmp/owrt_-_flint-v2_-_usb_ipks/; opkg install parted*.ipk , pls.
root@GL-MT6000:/# cd /tmp/owrt_-_flint-v2_-_usb_ipks/; opkg install parted*.ipk
Unknown package 'parted'.
Collected errors:
 * pkg_hash_check_unresolved: cannot find dependency libreadline8 for parted
 * pkg_hash_check_unresolved: cannot find dependency libncurses6 for parted
 * pkg_hash_fetch_best_installation_candidate: Packages for parted found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package parted.
root@GL-MT6000:/tmp/owrt_-_flint-v2_-_usb_ipks#
I expect this to fail installation but let’s be as specific as possible:
opkg install parted_3.6-1_aarch64_cortex-a53.ipk
(still when within /tmp/owrt_-_flint-v2_-_usb_ipks/)
root@GL-MT6000:/tmp/owrt_-_flint-v2_-_usb_ipks# opkg install parted_3.6-1_aarch6
4_cortex-a53.ipk
Collected errors:
find /tmp -iname libreadline8*; find -/tmp -iname libncurses6*
oot@GL-MT6000:~# find /tmp -iname libreadline8*; find -/tmp -iname libncurses6*
/tmp/owrt_-flint-v2-_usb_ipks/libreadline8_8.2-1_aarch64_cortex-a53.ipk
find: unrecognized: -/tmp
BusyBox v1.36.1 (2024-01-25 22:45:41 UTC) multi-call binary.
Usage: find [-HL] [PATH]… [OPTIONS] [ACTIONS]
Search for files and perform actions on them.
First failed action stops processing of current file.
Defaults: PATH is current directory, action is ‘-print’
-L,-follow	Follow symlinks
-H		...on command line only
-xdev		Don't descend directories on other filesystems
-maxdepth N	Descend at most N levels. -maxdepth 0 applies
		actions to command line arguments only
-mindepth N	Don't act on first N levels
-depth		Act on directory *after* traversing it
Actions:
( ACTIONS ) Group actions for -o / -a
! ACT Invert ACT’s success/failure
ACT1 [-a] ACT2 If ACT1 fails, stop, else do ACT2
ACT1 -o ACT2 If ACT1 succeeds, stop, else do ACT2
Note: -a has higher priority than -o
-name PATTERN Match file name (w/o directory name) to PATTERN
-iname PATTERN Case insensitive -name
-path PATTERN Match path to PATTERN
-ipath PATTERN Case insensitive -path
-regex PATTERN Match path to regex PATTERN
-type X File type is X (one of: f,d,l,b,c,s,p)
-perm MASK At least one mask bit (+MASK), all bits (-MASK),
or exactly MASK bits are set in file’s mode
-mtime DAYS mtime is greater than (+N), less than (-N),
or exactly N days in the past
-mmin MINS mtime is greater than (+N), less than (-N),
or exactly N minutes in the past
-newer FILE mtime is more recent than FILE’s
-user NAME/ID File is owned by given user
-group NAME/ID File is owned by given group
-size N[bck] File size is N (c:bytes,k:kbytes,b:512 bytes(def.))
+/-N: file size is bigger/smaller than N
-prune If current file is directory, don’t descend into it
If none of the following actions is specified, -print is assumed
-print Print file name
-print0 Print file name, NUL terminated
-exec CMD ARG ; Run CMD with all instances of {} replaced by
file name. Fails if CMD exits with nonzero
root@GL-MT6000:~#
find /tmp -iname libreadline8* && find /tmp -iname libncurses6*
I had a typo. Try this one: the && tells the CLI’s shell interpreter to wait until the first command is finished before executing the second command.
root@GL-MT6000:~# find /tmp -iname libreadline8* && find /tmp -iname libncurses6
/tmp/owrt_-_flint-v2_-_usb_ipks/libreadline8_8.2-1_aarch64_cortex-a53.ipk
/tmp/owrt_-_flint-v2_-_usb_ipks/libncurses6_6.4-2_aarch64_cortex-a53.ipk
root@GL-MT6000:~#
Okay, so we know all the dependances require for the parted package are there but not installed. Updated script incoming. You’ll just need to upload it to the Flint-v2 /tmp dir & chmod, then install. Standby…
# // Last modified: 20240201 02:36:59
# // Created: 20240127 10:08:26
* updated InstallToOwrt opkg install cmd for gobbing
owrt_-flint-v2-_get_usb.tar|attachment (20 KB)
oot@GL-MT6000:/tmp# ./owrt_-_flint-v2_-_get_usb.sh install
Package openssh-sftp-server (9.6p1-1) installed in root is up to date.
Package block-mount (2024-01-22-08cd7083-1) installed in root is up to date.
Unknown package 'cgdisk'.
Collected errors:
 * pkg_hash_check_unresolved: cannot find dependency libstdcpp6 for cgdisk
 * pkg_hash_check_unresolved: cannot find dependency libncursesw6 for cgdisk
 * pkg_hash_fetch_best_installation_candidate: Packages for cgdisk found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package cgdisk.
Package libc (1.2.4-4) installed in root is up to date.
Package libcap-bin (2.69-1) installed in root is up to date.
Package libcap-ng-bin (0.8.3-2) installed in root is up to date.
Package libcap-ng (0.8.3-2) installed in root is up to date.
Package libcap (2.69-1) installed in root is up to date.
Package libcares (1.19.1-1) installed in root is up to date.
Package libcbor0 (0.8.0-1) installed in root is up to date.
Package libcharset1 (1.17-1) installed in root is up to date.
Package libcli (2022-07-06-V1.10.7) installed in root is up to date.
Package libcoap3 (4.3.0-2) installed in root is up to date.
Package libcomerr0 (1.47.0-2) installed in root is up to date.
Package libconfig11 (1.7.3-1) installed in root is up to date.
Unknown package 'libctf'.
Unknown package 'libcurl-gnutls4'.
Unknown package 'libcurl4'.
Collected errors:
 * pkg_hash_check_unresolved: cannot find dependency libbfd for libctf
 * pkg_hash_fetch_best_installation_candidate: Packages for libctf found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package libctf.
 * pkg_hash_check_unresolved: cannot find dependency libgnutls for libcurl-gnutls4
 * pkg_hash_check_unresolved: cannot find dependency libidn2 for libcurl-gnutls4
 * pkg_hash_check_unresolved: cannot find dependency zlib for libcurl-gnutls4
 * pkg_hash_fetch_best_installation_candidate: Packages for libcurl-gnutls4 found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package libcurl-gnutls4.
 * pkg_hash_check_unresolved: cannot find dependency libnghttp2-14 for libcurl4
 * pkg_hash_fetch_best_installation_candidate: Packages for libcurl4 found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package libcurl4.
Unknown package 'libncursesw6*'.
Collected errors:
 * opkg_install_cmd: Cannot install package libncursesw6*.
Installing libstdcpp6 (12.3.0-4) to root...
Configuring libstdcpp6.
Package libuuid1 (2.39.3-1) installed in root is up to date.
Package e2fsprogs (1.47.0-2) installed in root is up to date.
Package f2fs-tools (1.16.0-2) installed in root is up to date.
Package f2fsck (1.16.0-2) installed in root is up to date.
Package mkf2fs (1.16.0-2) installed in root is up to date.
Collected errors:
Unknown package 'libncurses6'.
Collected errors:
 * pkg_hash_check_unresolved: cannot find dependency terminfo for libncurses6
 * pkg_hash_fetch_best_installation_candidate: Packages for libncurses6 found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package libncurses6.
Package libparted (3.6-1) installed in root is up to date.
Unknown package 'libreadline8'.
Collected errors:
 * pkg_hash_check_unresolved: cannot find dependency libncursesw6 for libreadline8
 * pkg_hash_fetch_best_installation_candidate: Packages for libreadline8 found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package libreadline8.
Package libblkid1 (2.39.3-1) installed in root is up to date.
Unknown package 'usbutils'.
Collected errors:
 * pkg_hash_check_unresolved: cannot find dependency libusb-1.0-0 for usbutils
 * pkg_hash_check_unresolved: cannot find dependency libudev for usbutils
 * pkg_hash_fetch_best_installation_candidate: Packages for usbutils found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package usbutils.
Package libpthread (1.2.4-4) installed in root is up to date.
Package librt (1.2.4-4) installed in root is up to date.
Unknown package 'librtlsdr'.
Collected errors:
 * pkg_hash_check_unresolved: cannot find dependency libusb-1.0-0 for librtlsdr
 * pkg_hash_fetch_best_installation_candidate: Packages for librtlsdr found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package librtlsdr.
Unknown package 'libudev-zero'.
Collected errors:
 * pkg_hash_check_unresolved: cannot find dependency libevdev for libudev-zero
 * pkg_hash_fetch_best_installation_candidate: Packages for libudev-zero found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package libudev-zero.
Unknown package 'libusb-1.0-0'.
Collected errors:
 * pkg_hash_check_unresolved: cannot find dependency libatomic1 for libusb-1.0-0
 * pkg_hash_fetch_best_installation_candidate: Packages for libusb-1.0-0 found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package libusb-1.0-0.
Package kmod-crypto-crc32 (5.15.147-1) installed in root is up to date.
Package kmod-crypto-crc32c (5.15.147-1) installed in root is up to date.
Package kmod-fs-exfat (5.15.147-1) installed in root is up to date.
Package kmod-fs-ext4 (5.15.147-1) installed in root is up to date.
Package kmod-fs-f2fs (5.15.147-1) installed in root is up to date.
Package kmod-lib-crc16 (5.15.147-1) installed in root is up to date.
Package kmod-scsi-core (5.15.147-1) installed in root is up to date.
Package kmod-usb-storage-extras (5.15.147-1) installed in root is up to date.
Package kmod-usb-storage-uas (5.15.147-1) installed in root is up to date.
Package kmod-usb-storage (5.15.147-1) installed in root is up to date.
Unknown package 'libbfd'.
Collected errors:
 * pkg_hash_check_unresolved: cannot find dependency zlib for libbfd
 * pkg_hash_fetch_best_installation_candidate: Packages for libbfd found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package libbfd.
Package libblobmsg-json20240126 (2024-01-26-c1be5057-1) installed in root is up to date.
Package libf2fs6 (1.16.0-2) installed in root is up to date.
Unknown package 'libgnutls-dane'.
Installing libgnutls (3.8.3-1) to root...
Collected errors:
 * pkg_hash_check_unresolved: cannot find dependency libnettle8 for libgnutls
 * pkg_hash_check_unresolved: cannot find dependency libgmp10 for libgnutls
 * pkg_hash_check_unresolved: cannot find dependency libatomic1 for libgnutls
 * pkg_hash_fetch_best_installation_candidate: Packages for libgnutls found, but incompatible with the architectures configured
 * pkg_hash_check_unresolved: cannot find dependency libunbound for libgnutls-dane
 * pkg_hash_fetch_best_installation_candidate: Packages for libgnutls-dane found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package libgnutls-dane.
 * satisfy_dependencies_for: Cannot satisfy the following dependencies for libgnutls:
 * 	libnettle8
 * 	libgmp10
 * 	libatomic1
 * opkg_install_cmd: Cannot install package libgnutls.
Installing libatomic1 (12.3.0-4) to root...
Configuring libatomic1.
Installing libgmp10 (6.3.0-1) to root...
Configuring libgmp10.
Installing libnettle8 (3.9.1-1) to root...
Configuring libnettle8.
Collected errors:
 * pkg_hash_check_unresolved: cannot find dependency libgnutls for libgnutls-dane
Unknown package 'libunbound'.
Collected errors:
 * pkg_hash_check_unresolved: cannot find dependency libopenssl3 for libunbound
 * pkg_hash_check_unresolved: cannot find dependency libevent2-7 for libunbound
 * pkg_hash_fetch_best_installation_candidate: Packages for libunbound found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package libunbound.
Installing libevdev (1.13.0-1) to root...
Configuring libevdev.
Unknown package 'libevdev-zero*'.
Collected errors:
 * opkg_install_cmd: Cannot install package libevdev-zero*.
Unknown package 'libidn2'.
Collected errors:
 * pkg_hash_check_unresolved: cannot find dependency libunistring for libidn2
 * pkg_hash_fetch_best_installation_candidate: Packages for libidn2 found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package libidn2.
Installing libunistring (1.1-1) to root...
Configuring libunistring.
Installing terminfo (6.4-2) to root...
Configuring terminfo.
Installing libnghttp2-14 (1.57.0-1) to root...
Configuring libnghttp2-14.
Installing libpopt0 (1.19-1) to root...
Configuring libpopt0.
Package libubox20240126 (2024-01-26-c1be5057-1) installed in root is up to date.
Installing zlib-dev (1.3-1) to root...
Installing zlib (1.3-1) to root...
Package zlib (1.3-1) installed in root is up to date.
Configuring zlib.
Configuring zlib-dev.
root@GL-MT6000:/tmp#
Humm… so that failed. Let’s try manually installing parted again:
root@GL-MT6000:/tmp# cd owrt_-_flint-v2_-_usb_ipks
4_cortex-a53.ipk
Collected errors:
I gotta look at the OWRT snapshot repos. Standby…
parted is missing libncurses6 which is missing libpthread which is missing libgcc1.
See what I was talking about? This is all for one program… one used to set up storage disk partitions. Welcome to dependency Hell.
New script incoming. You’ll have to run it fr Ubuntu to get the new package & upload it all to the Flint-v2. Standby…
# // Last modified: 20240201 03:05:54
* libgcc1 added to parted deps in ipkList
root@GL-MT6000:/tmp# ./owrt_-_flint-v2_-_get_usb.sh install
Collected errors:
Installing libcurl4 (8.5.0-1) to root...
Configuring libcurl4.
Collected errors:
Collected errors:
Package libstdcpp6 (12.3.0-4) installed in root is up to date.
Collected errors:
Installing libncurses6 (6.4-2) to root...
Configuring libncurses6.
Installing libreadline8 (8.2-1) to root...
Configuring libreadline8.
Collected errors:
Collected errors:
Package libgcc1 (12.3.0-4) installed in root is up to date.
Collected errors:
Installing libudev-zero (1.0.3-1) to root...
Configuring libudev-zero.
Installing libusb-1.0-0 (1.0.26-3) to root...
Configuring libusb-1.0-0.
Installing libbfd (2.41-1) to root...
Configuring libbfd.
Configuring libgnutls.
Collected errors:
Package libatomic1 (12.3.0-4) installed in root is up to date.
Package libgmp10 (6.3.0-1) installed in root is up to date.
Package libnettle8 (3.9.1-1) installed in root is up to date.
Collected errors:
Collected errors:
Package libevdev (1.13.0-1) installed in root is up to date.
Collected errors:
Installing libidn2 (2.3.4-1) to root...
Configuring libidn2.
Package libunistring (1.1-1) installed in root is up to date.
Package terminfo (6.4-2) installed in root is up to date.
Package libnghttp2-14 (1.57.0-1) installed in root is up to date.
Package libpopt0 (1.19-1) installed in root is up to date.
Package zlib-dev (1.3-1) installed in root is up to date.
ls -l /tmp/owrt_-_flint-v2_-_usb_ipks/ | awk '{print $9}' output pls.
