VPN Led doesn't work with Tailscale
Hello, I have a GL-MT2500 configured to connect to Tailscale as a gateway node.
The device connects fine to Tailscale but the VPN indication led doesn’t light up.
Can you please advise whether this is a bug or a feature to come in the very near future?
If so, can you also provide a workaround to have the VPN led reflect the Tailscale connection status?
Thank you in advance
I have reported and recorded this issue, and the future firmware will consider modifying it.
