hi i need help i set up everything , server and client to get vpn from my abroad home conection
this has worked fine using the certificate on my phone and on my laptop so i decided to buy the ax1800 so i just have a diferent wifi allways vpn’d
i have loaded the vertificate fallowd all steps and i get a succesfull conection but i cannot navigate, keep in mind that AX router is behind the exact same comcast router that i have used to conect via app on laptop and phone so its not modem or isp block
can any one guide me or did i get a bad device ?
here is my log
Thu Oct 6 13:06:47 2022 daemon.notice ovpnclient[9994]: TUN/TAP device ovpnclient opened
Thu Oct 6 13:06:47 2022 daemon.notice ovpnclient[9994]: net_iface_mtu_set: mtu 1500 for ovpnclient
Thu Oct 6 13:06:47 2022 daemon.notice ovpnclient[9994]: net_iface_up: set ovpnclient up
Thu Oct 6 13:06:47 2022 daemon.notice ovpnclient[9994]: net_addr_v4_add: 10.8.0.4/24 dev ovpnclient
Thu Oct 6 13:06:47 2022 daemon.notice ovpnclient[9994]: /etc/openvpn/scripts/ovpnclient-up ovpnclient 0 ovpnclient 1500 1624 10.8.0.4 255.255.255.0 init
Thu Oct 6 13:06:47 2022 daemon.info avahi-daemon[4245]: Joining mDNS multicast group on interface ovpnclient.IPv4 with address 10.8.0.4.
Thu Oct 6 13:06:47 2022 daemon.info avahi-daemon[4245]: New relevant interface ovpnclient.IPv4 for mDNS.
Thu Oct 6 13:06:47 2022 daemon.info avahi-daemon[4245]: Registering new address record for 10.8.0.4 on ovpnclient.IPv4.
Thu Oct 6 13:06:47 2022 user.notice ovpnclient-up: env value:route_vpn_gateway=10.8.0.1 daemon_log_redirect=0 script_type=up proto_1=udp daemon=0 SHLVL=1 dev_type=tun remote_1=mk7XXXX.glddns.com dev=ovpnclient X509_0_CN=OpenVpn server remote_port_1=1194 X509_1_CN=OpenVPN CA ifconfig_netmask=255.255.255.0 tls_digest_sha256_0=93:8a:89:53:4d:ab:64:cc:8c:6f:cb:cc:69:9c:1b:7c:ce:a6:ce:06:96:7b:76:14:81:c1:b9:b7:5d:aa:10:44 daemon_start_time=1665079601 script_context=init ifconfig_local=10.8.0.4 common_name=OpenVpn server tls_digest_sha256_1=15:84:2e:57:f5:5f:d2:1e:38:d7:06:40:9e:3a:ec:66:11:7c:10:65:18:f1:0a:eb:c3:26:49:2f:f5:eb:44:9a verb=3 link_mtu=1624 trusted_ip=201.xxx.246.xx tls_serial_hex_0=39:65:5e:cc:a5:05:6e:81:a2:05:27:a8:09:ef:14:c9:c8:89:58:78 tun_mtu=1500 tls_serial_hex_1=3c:11:e0:26:c1:66:85:48:13:ca:8c:2c:f5:49:58:59:70:21:bc:aa trusted_port=1194 tls_id_0=CN=OpenVpn server tls_id_1=CN=OpenVPN CA route_net_gateway=192.168.0.1 daemon_pid=9994 config=/tmp/ovpnclient/ovpnclient untrusted_ip=201.244.2X6.XX tls_serial_
Thu Oct 6 13:06:50 2022 daemon.info avahi-daemon[4245]: Interface ovpnclient.IPv4 no longer relevant for mDNS.
Thu Oct 6 13:06:50 2022 daemon.info avahi-daemon[4245]: Leaving mDNS multicast group on interface ovpnclient.IPv4 with address 10.8.0.4.
Thu Oct 6 13:06:50 2022 daemon.info avahi-daemon[4245]: Withdrawing address record for 10.8.0.4 on ovpnclient.
Thu Oct 6 13:06:50 2022 daemon.info avahi-daemon[4245]: Joining mDNS multicast group on interface ovpnclient.IPv4 with address 10.8.0.4.
Thu Oct 6 13:06:50 2022 daemon.info avahi-daemon[4245]: New relevant interface ovpnclient.IPv4 for mDNS.
Thu Oct 6 13:06:50 2022 daemon.info avahi-daemon[4245]: Registering new address record for 10.8.0.4 on ovpnclient.IPv4.
Thu Oct 6 13:06:50 2022 daemon.notice netifd: Interface 'ovpnclient' is now up
Thu Oct 6 13:06:50 2022 daemon.notice netifd: Network device 'ovpnclient' link is up
Thu Oct 6 13:06:50 2022 user.notice firewall: Reloading firewall due to ifup of ovpnclient (ovpnclient)
Thu Oct 6 13:06:52 2022 daemon.warn ovpnclient[9994]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Thu Oct 6 13:06:52 2022 daemon.notice ovpnclient[9994]: Initialization Sequence Completed```
