VPN Only For Router Processes?
If I want to use a VPN only for router processes because other clients have their own VPN, then I understand I need to enable the router processes option but also have a rule that only the router mac should use VPN.
Do you think this would work? Has anyone done this? How can I check if all router processes are using the VPN? Thank you
You can use VPN policy and set the following policies
Thank you for the reply a few months ago.
So setting “All Mac Addresses” to “Do not use vpn” will not include the router mac address? It only means all client mac addresses?
If so, this is what I wanted. Thank you.
Yes. “All Mac Addresses” does not include the router itself.
If you want to include the router itself, the “Use VPN for all processes on the router” is the correct option.
