Pls replace it and lets start over.
alzhao, I can report that with the Beryl running v.3.2, the effect of the two VPN policy rules is reversed. âUse VPN for the items in the listâ turns the VPN off for all but the listed clients/sites. âOnly allow the following use VPNâ turn the VPN on for all but the listed items. This is likely confounding a lot of users.
Correction:
âUse VPN for the items in the listâ turns the VPN off for the listed clients/sites.
âDo not use VPN for the followingâ turn the VPN on for the listed client/sites.
Sorry about that.
I just checked. IP based policy works fine. Can you test again?
You can clear you DNS cache?
I havenât had much luck getting this to work, either. Iâm on a GL-MT1300, though.
