Hello, I am using GL-AXT1800 as a travel router. I am trying to figure out how can I combine 2 different types of VPN routing policies that are easy to achieve independently of each other,
My first requirement is that remote lan(s) should be accessible by all clients at all times. “Customize routing rules” makes this happen while I am running a couple of vpns simultaneously.
2nd requirement is that all traffic goes through the tunnel. I can achieve this by policy based on VLAN for all clients, but would like to only apply to specific clients while the 1st requirement is in place.
Is there a way to achieve this?
Thank you!
