Hey! I just got two AX3000 to have one as a WireGuard Server in my house and another one as a WireGuard Client so I can access my work info when I'm traveling. However I've been trying to create the tunel between the two and it's been impossible. Port Forwarding for 51820 keeps closed even when I put the modem on bridge mode. I don´t know what else to do and I need it working for tomorrow.
Is there the public IP in home ISP (modem or GL MT3000)?
Home MT3000 as WG server does not need to configure port forwarding on itself. Just need to configure port forwarding on the ISP modem if the modem obtained the public IP.
Please refer to the 2 guides to check:
Seems like the issue is the internet provider (Spectrum) which blocks the ports. I haven't found a port Open. I found one earlier, used it and it got blocked in like 5 minutes. What can I do in this case?
You have to contact the ISP to know why the port is blocked.
You can change the VPN server port, such as 51820 changes to 51920, etc., but I'm afraid the ISP will block it again.
