i want to enable the vpn and the ip address should be from china how can possible that way. im connect the router from out side the china
You first need a VPN provider which provides a Chinese IP (not even sure if that exists, tbh.)
Then follow this: WireGuard Client - GL.iNet Router Docs 4
