I have an AR150 with 2.25 firmware installed and I am trying to set up a VPN.
I have set up a paid account with FinchVPN and followed the set up instructions here:
However I can not connect successfully and keep getting an Auth Fail error message:
I have a FinchVPN login UserName and Password, and the generayed API Key. I followed the instructions above to get the ovpn file for a selected server from the list, ticked the box for “username and password (API Key)” and downloaded the ovpn file.
When I upload the ovpn file I am prompted for Username and Password, and I put in the account Username and the API Key.
Is this the correct credentials to use?
When I click the Apply button, the log shows a connection attempt which ends with failure as follows:
"OpenVpn is not started
Last log Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 2048 bit RSA [server] Peer Connection Initiated with [AF_INET]144.217.89.176:8484 SENT CONTROL [server AUTH: Received control message: AUTH_FAILED SIGTERM[soft,auth-failure] received, process exiting "
Have I misunderstood the set up instructions in some way, or is there something wrong?
Many thanks in advance for your help.
Terry
