I’m a Network Newbie here. Purchased AR-750S-Ext (Slate) and installed it in the following mode.
ISP → Motorola Surfboard Cable Modem → Netgear Router → AR750S-Ext (Slate) (repeater mode)
Enabled VPN in AR750S-Ext (Slate) (OpenVPN and installed config from KeepSolid VPN Unlimited) and connected my laptop to the Wifi
- How do I test and find out if all my laptop traffic is going through the VPN?
- What are the settings in AR750S-Ext (Slate) which will ensure that if my commercial VPN is down, then it will block internet access?
- How do i prevent DNS Leak via setups
- How do I test for DNS Leak?
Thanks,
