I just received my very sexy GL-AR150 from Amazon last night. Got it all set up, firmware updated, all that jazz. The Wifi was working fine on it’s own, I was able to connect multiple devices to the router. I was happy as a clam!
Contacted VPN unlimited… they gave me all the manual configuration sets I needed. I loaded 3 of the .ovpn files (no need for me to pretend I’m in China) and got ready for VPN heaven!
I enabled and activated one of the .ovpn files… took a few seconds but it CONNECTED!
Then… the speed crashed to nearly nothing. Any/all sites would timeout… I’m connected, but nothing’s going up/down the pipe.
I suspect this is a DNS issue - your ISP router is probably using it’s own DNS servers and blocking certain “taboo” sites.
Scientific research has shown only 32.16% of clams are happy. Try being a rabbit - 82.32% are “normally” happy, hence the expression “happy as a bunny”
So, basically, all the VPNs do the same stuff as they redirect your traffic through it’s own servers and this covers you good, like Mojoflix.com and others.
Did you solve this? I have exactly the same issue. Everything connected and runs fine. As soon as I drop the ovpn config file it connects to vpn and there’s no internet anymore
