VPN very slow with ar-150
i’ve huge problems with my vpn speed concerning my router gl-ar150 and airvpn (with openvpn configfile from airpn)
the router hangs directly to my ISP (Austria), than futher with lan to my smart tv
normaly my speed is about 35 Mbit/Down (with this constellation only about 1 Mbit !!)
i use a configfile with UDP 443 with server from the netherlands
Any help would be appreciated
thx
The AR150 really doesn’t have the hardware chops for reasonable VPN speed, I’d recommend you check out the MT300N (up to 10mbps) or AR300M (up to 17mbps).
